Does Python Close Session close open ports in py file?
I am running a Python script to open a port to a TCP connection.  However, in the second session, when trying to run the scrip again, I get an error that the TCP connection was refused.
In the python script, I open and close the TCP port like this:
def TCP_socket_conn():
    # create TCP socket and UBX reader object
    HOST = "102.104.22.33"
    PORT = 1056
    s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
    s.connect((HOST, PORT))
    ubr = UBXReader(s, protfilter=2)
    return s, ubr
s, ubr = TCP_socket_conn()
<<RUN SOME CODE>>
s.close()
It works the first time, but I get the error the second attempt and I have to reset the TCP connection.
Here is a snippet of the LabVIEW Python call:
 Does LabVIEW automatically close the TCP port?
As an aside, when I also do this to talk to a piece of equipment, I also get an error the second go around if I close the pyvisa session.  Here is an example of the python code:
import pyvisa
import time
t = 0.5
rm = pyvisa.ResourceManager()
instrument = rm.open_resource('TCPIP0::05.20.133.05::8856::SOCKET')
def power_level(command):
    instrument.write(command)
# shutdown
rm.close()
 Any guidance is sincerely appreciated.
Thanks!
(3,357 Views)
Could it be a conflict of resources?...as I am opening the instrument's TCPIP port:
then opening the device port:
then in the end, doing a:
s.close()
(3,328 Views)
Not sure about the Python implementation of TCP-IP sockets but in the case of your pyVISA implementation I would definitely try to do a close of the instrument session too, before closing of the resource manager session.
import pyvisa
import time
t = 0.5
instrument.close()
# shutdown
rm.close()
Rolf Kalbermatter  My Blog
(3,264 Views)
