08-24-2005 10:59 AM
We have an application here based on the NI Labview Test executive (V4.0). Recently the ISA NISCOPE card packed it in and a new PCI version was purchased. The card did not work in the app and when the engineer installed the new driver, it automatically removed the old driver - and still didn't work.
I would like to know what our options are at this point. Here are a few questions:
1. We need to use the new PCI NISCOPE card and driver. Since the PCI driver only works in a newer version of LV than what they are using, I would have to use the latest Labview we have (7.1) and convert the vis. My question is does NI still sell the Labview Test Exec? If yes, what version would work with 7.1?
2. If National does not sell the Labview test exec, I have a copy of labview V5.1 and the corresponding Test exec. I guess I could use this to rebuild the app, but would the PCI driver work with this?
I'm looking for the simplest (cheapest) way to support an old project. Has anyone else had to deal with this problem?
Thanks for your help,
Howard Spec
CMC Electronics
08-24-2005 11:46 AM
08-24-2005 11:52 AM
Just a guess here, but I would think the new driver doesn't support your old version of LabVIEW. Support for older versions is dropped as newer versions are released. All companies do this because it gets to be too expensive to support everything.
No, LabVIEW Test Exec is not available any more. It's been replaced with TestStand.1. We need to use the new PCI NISCOPE card and driver. Since the PCI driver only works in a newer version of LV than what they are using, I would have to use the latest Labview we have (7.1) and convert the vis. My question is does NI still sell the Labview Test Exec? If yes, what version would work with 7.1?
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
