Does Labview FPGA support Spartan-3E (1600Kgate) kit?
I wonder whatever Labview FPGA supports Spartan-3E (1600Kgate) kit?
It's already sypport Sartan-3E (500Kgate) kit.
Message 1 of 11
(6,169 Views)
Yes, Labview fpga supports SPARTAN-3E xc3s500e fg320.  But, u have to install driver.
U can download this driver from this link
https://lumen.ni.com/nicif/us/infolvfpgaxilsprtn/content.xhtml
see this link also
http://digital.ni.com/express.nsf/bycode/spartan3e?opendocument〈=en&%2338;node=seminar_US
post ur queries (if u have any)
Prashh
Message 2 of 11
(6,158 Views)
I know that Spartan-3E (500Kgate) is sypported!
I'm asking about Spartan-3E (1600Kgate), does it work with the same driver?
Message 3 of 11
(6,153 Views)
Currently the Spartan 3E XUP driver only officaly supports the Spartan 3E starter board (500kgate). If you are interested in using LabVIEW FPGA with The Spartan 3E developers board (1600kgate) please submit a product suggestion, so our developers know.
Message 4 of 11
(6,096 Views)
Recently I acquire the Spartan 3E-1600 Development Board.I tried to figure out how to "restructure" the files by modifying the following files in this path: C:\NIFPGA86\Xilinx\spartan3e\data - xc3s500e.bsd ---> xc3s1600e.bsd- 3s500e.xxx ---> 3s1600e.xxxI succeeded in the first compiling stage , but still having problems when is recognizing the component ID (from 29499539----> 3E500 to 29597843---->3E1600), of course I change the binary ID tags without the required result. I observed that it has something to do with the 3sXXXe.nph file but as it is encrypted there is no way to modify it.I suppose that develop a driver for the other board wont be too much problem. Already sent a product suggestion, but I assume it will take long to obtain it. There is some walk-around for this?
Message 5 of 11
(5,939 Views)
Unfortunately developing this driver may take some time. For the time being product suggestions will be the best way to show your support.
Message 6 of 11
(5,925 Views)
Does Labview FPGA support Spartan-3E (1600Kgate) kit now??????
Message 7 of 11
(5,428 Views)
hello dear,
If you can tell me how i can use Spartan-3E (1600Kgate) kit with labveiw I SHALL BE VERY THANK FULL FOR YOUR ANSWER
Message 8 of 11
(5,280 Views)
Unfortunately, the 1600Kgate Spartan-3E is not currently supported. As Hueter mentioned, the fastest way to be heard on this issue is to submit a product suggestion (you can do so here).
Caleb Harris
National Instruments | http://www.ni.com/support
Message 9 of 11
(5,249 Views)
I  hae labview vi.now i want to create labview fpga vi and would like to port it on xilinx virtex 4 fpga.when i open the project explorer and adding target and devices there is no fpga target. what should i do?
Message 10 of 11
(4,549 Views)
