Does LabVIEW still support ARM microcontrollers?
I have seen the following paragraph in ni.com and I am about to do a project with ARM microcontroller STM32F407. I want to know if labview does not support ARM after 2012, what is the alternative solution in newer vervions? Is there a new module for ARM microcontrollers?
"NI LabVIEW 2012 is the last version of the system design software that is compatible with the LabVIEW Embedded Module for ARM Microcontrollers. For new designs, NI recommends using devices based on the LabVIEW reconfigurable I/O (RIO) architecture such as NI CompactRIO or NI Single-Board RIO instead. Contact your sales representative for more information on alternatives for new designs."
(4,963 Views)
That paragraph translates to "NI no longer supports this toolkit.  As a result, here's what NI suggests you use instead."
That should answer your questions.
(4,913 Views)
