Does LabVIEW need to know which network to use?
I have a LabVIEW standalone application installed in a client machine(Intel NUC with WiFi connected to an internet hotspot) which uses 'SMTP client' VI & 'FTP put file' VI's to automatically generate email & upload .csv files everyday.
The emails were coming everyday & the files were also getting uploaded....all was well.
Now , we had to put in an additional USB WiFi dongle(WiFi2) to link with a separate access point(not internet connected) to connect to some I.P enabled devices in the intranet through the browser.
Since then , the automatic mailing & uploading have stopped.
I have a feeling that the LabVIEW code is trying to access internet through WiFi2 and failing.
Does LabVIEW know which network to use?
.....or , if I rephrase my question , is there any way by means of which LabVIEW can be forced to use WiFi & NOT WiFi2?
(2,246 Views)
This might be the issue, I have had similar before in LabVIEW when adding a 3g dongle messed up some TCP/IP connections for me.
There's normally some metric that determines the priority of each interface. How you adjust this depends on the OS. I think you can set the metric in windows 10 from advanced network setting, but you should find easily enough by searching Google for "network priority".
0xDEAD
(2,225 Views)
