Does LabVIEW need an entry point in a DLL
We are trying to communicate with a time-to-digital converter card via a DLL provided by the manufacturer. However, this DLL does not seem to have a defined entry point as when we have used Visual Basic 6, VB it errors and tells us there is no entry point.
We can write a wrapper DLL in C but in terms of overheads it would be preferable to go to the original DLL direct.
I know labVIEW can easily load DLLs but can it load a DLL without an entry point? We have a header file which defines the functions.
I hope you can help.
(2,648 Views)
The DLL will require an entry point in order for LabVIEW to communicate with it much the same as other languages, otherwise the DLL is a resource and not something useable. The only real way to get this working is to a) wrapper it in C as you noted or b) write the DLL from scratch with an entry point.
All the best,
(2,629 Views)
Rob,
     Thanks, looks like I'll have to make a wrapper.
(2,626 Views)
