取消
显示结果
搜索替代
您的意思是:
Does LabVIEW have a method to represent a VI in terms of "number of lines of code?"
0 项奖励
1 条消息(共 5 条)
2,956 次查看
Right click on the front panel icon and select vi properties... (for labview 5.x its under file menu). Then choose memory usage. You can get some stats here such as memory used by code, by front panel objects, by data.
Jared
2 条消息(共 5 条)
2,956 次查看
Thanks for quick repsonse. It looks like the tradional manner of quantifying software code by "number of lines" is changing: e.g. LabVIEW only displays Memory Useage amounts. No problem, just have to update others as to the new and improved way.
0 项奖励
3 条消息(共 5 条)
2,956 次查看
You might want to look at the VI Metrics Tools available in the Professional Developers version. One thing it lists is the number or nodes. According to the toolkit documentation, nodes are analgous to statements, operators, and subroutine calls in conventional languages and gives a number comparable to source lines of code.
0 项奖励
4 条消息(共 5 条)
2,956 次查看
Thanks, I'll look into that.
0 项奖励
5 条消息(共 5 条)
2,956 次查看
