Documentation for DSSetHandleSize
Hi everyone,
I'm new to LabVIEW, so I apologize in advance for any mistakes or confusion in my question.
I'm trying to pass arrays or clusters from my DLL to LabVIEW. Here's the solution I've implemented:
Spoiler
typedef struct {
int32_t dimSize;
int32_t elt[1];
} Array1DInt;
typedef Array1DInt** A1DDhandle;
void __declspec(dllexport) getArray1D(A1DDhandle arr)
int i; // Allocate memory for 4 elements DSSetHandleSize
(arr, sizeof(int32_t) + 4 * sizeof(int32_t));
(*arr)->dimSize = 4;
for (i = 0; i < 4; i++)
{ (*arr)->elt[i] = (i + 1) + 420; }
I gathered this code from various YouTube videos and forum entries, but I'd like to understand it better. Specifically, I'm looking for proper documentation for the functions from extcode.h. I couldn't find anything useful.
Can someone point me to detailed documentation ?
Thanks in advance for your help!
(896 Views)
Accepted by topic author alarmedWater
Is this detailed enough DSSetHandleSize? In your case you can use NumericArrayResize, so that you do not need to take the size part into account.
There is an example shipping with LabVIEW at LabVIEW 20XX\examples\Connectivity\Libraries and Executables\External Code (DLL) Execution.vi
Source C Files\LVLStrHandle.c contains an example using DSSetHandleSize, CLUSTERComplex.c contains an example using NumericArrayResize and shows how to handle dynamically sized data types in a cluster.
(848 Views)
