Dll
When a window is created (this can be a real window, but also a standard
windows control), the operating system creates one for you, and passes back
a hWnd, a window handler.
The dll function that you are calling will probably use the hWnd it is given
to create a child window, with the passes hWnd as parent. This results in a
window created by the dll that is modal to the parent window. But as
indicated by the prototype, it also takes a NULL (0), so you do not need to
spend much time on it. If you still want to try passing a hWnd to the
function, use windows API FindWindowA of FindWindowExA to get one, but these
functions are more advanced then the function you are trying to get
working...
Wiebe.
Message 11 of 11
(493 Views)
