09-14-2014 11:36 PM
Hello everyone. I am new to the forum and have a problem with 3D images.
Figures appear incomplete or distorted. I have read that it can be a problem regarding OpenGL settings and the video card in that case I would like to help me set it up.
These are my Hardware features:
Core 2 Quad Processor
MB Asus P5Q3
4GB RAM
Video Card NVIDIA GF GT630 (with OpenGL and CUDA Support)
I tested this on two computers and always with the same results.
Please, I need URGENT !!!
Attached some pictures from the issue (examples of LabView: linear inverted pendulum, pendubot, F14 Tomcat Longitudinal Simulation)
Solved! Go to Solution.
09-15-2014 10:13 AM - edited 09-15-2014 10:16 AM
hmmm.... I think I've seen this before. Is your machine setup to use 'comma' as a decimal point? The import VRML file will not work well if that is the case.... LabVIEW has an option to ignore decimal point localization in Tools >> Options... >> Front panel: Use locallzed decimal point* . Uncheck and reinicialize LabVIEW.
Let us know if that helps,
09-15-2014 01:25 PM
09-17-2014 10:20 AM
hmm.. that is strange.... it used to work.... Then, your option is just change the decimal in the OS from "comma" (,) to "period" (.).
I tried here on a French OS and I was able to read the file correctly...
09-18-2014 12:15 AM - edited 09-18-2014 12:18 AM
Hello again with good news...
I tried both changing the comma from LabView as the change from the OS and it worked.
Thank you very much for the help.
