Displaying relative time in a chart?
How do I display the elapsed time on the x-axis in a chart? I have tried to change the formating of the x-axis (by right click on it) to "relative time", but the time showed has nothing with real time to do. It just increments a "second" every time the chart executes, see the simple attached example. Can anyone help?
(2,829 Views)
You need to use the Multiplier property. Right-click on the chart's terminal, select Create>>Property Node and then select X-scale>>Offset&multiplier>>Multiplier. Then, If you're going for 5 ms wire 0.005, if you're going for 100 ms wire 0.1 and so on.
___________________
Try to take over the world!
(2,823 Views)
thank you very much!
(2,819 Views)
