Displaying an incorrect X axis timescale in a XY graph
I'm trying to display 3 variables built with a cluster (time & numeric format).
When I format de X-axis as date, the value points doesn't correspond with the day in the plot.
Any idea what is happening?
The marker spacing of the X-axis seems to be 5, however, when it arrives to 28/10, the next mark is 01/11(!) instead of 02/11.
I'm using LabVIEW 2020 on Win10.
(2,033 Views)
check this please
CLA
(2,005 Views)
Using LabVIEW on another computer, it happens the same issue.
(1,982 Views)
Accepted by topic author vicens
What if you show hours and minutes too? Are you sure that the HH:MM part of the date is null? If not, the actual shift may be shorter than 5 days.
Paolo
(1,974 Views)
When I show the time option in the X-axis, it  appears 23:00:00(!) instead 00:00:00. So, the solution is to fix the time in the X-axis
(1,959 Views)
