Displaying URL in tree
Hello Everyone,
              I need to display URLs / web links in tree. When the user selects a particular web link it should open that web link in a seperate window. How can this be done?
Vasanth.
Ya Ya
(3,537 Views)
All the column items in the particular column will be links only. So, if I could just make all the entries for that column (by setting some property to the whole column) to display underlined, that would be enough to appear it like a link. Any suggestions for that?
Vasanth.
Ya Ya
(3,535 Views)
Vasanth,
I would use a Property Node to set the Cell Font to be underlined and blue.  Then if you want the links to be launched in the default web browser when clicked I would suggest using an event structure coupled with the Open URL in Default Browser VI (which you can find here: Functions»Dialog & User Interface»Help»Open URL in Default Browser.vi).
The end result would look something like this:
I hope this helps you get started,
Simon H
http://www.ni.com/support/
Message Edited by Simon H on 01-17-2007 07:15 PM
Message Edited by Simon H on 01-17-2007 07:16 PM
Message Edited by Simon H on 01-17-2007 07:17 PM
(3,520 Views)
Simon,
        Thanks for your suggestion. The vi you suggested for opening the link in the browser worked fine but I could not set the cell properties to make it appear as a link because I am using LabVIEW 7.1. Sorry I did not mention this before. Is there a way to display it in the same way as you did in LabVIEW 8.2?
Vasanth.
Ya Ya
(3,502 Views)
Vasanth,
I don't believe you can set a cell to be underlined programmatically in LabVIEW 7.x.  If this tree is populated prior to run-time you could change the font settings manually (by selecting each cell and pressing Ctrl+0 to bring up the font dialog box).
You can however change the color of the text using the Active Cell Properties»Foreground Color property.
Simon
(3,488 Views)
Simon,
        Thanks. Ok then, I will display the links as plain text and inform explicitly that it is a link.
Vasanth.
Ya Ya
(3,479 Views)
