Displaying Max/Min values with time for analog signals.
Thanks for your help. I will give it a try. One further question....I am using a strip chart to desplay these values. I have set the time interval on my while loop to 1 minute. I would like the x axis to pick up the default windows time/date without me having to allways set the start time and the interval manually. Thanks again!
Michael
Message 11 of 13
(943 Views)
Strip charts are kind of funny because they essentially represent a moving window over a (potentially) much larger trace memory. Unless you change the update mode, the right-hand edge of the strip-chart will by default always be the last value ou added to the chart. The left hand edge will be a fixed number of samples before the right edge. You can right-click on the graph and display a scrollbar that lets you scroll this fixed-size window across all the data that is in the chart memory. You set the size of this memory (in number of samples) by right-clicking on the graph and selecting "Chart History Length..."
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 13
(758 Views)
I am also trying to display the maximum values and time of maximums for the project I am doing.
I can't seem to find the max/min function for my program.
Using a thermocouple input device, I am reading in 3 thermocouples (USB), graphing them (on a waveform chart) and writing them to a file.
I can't figure out which max/min function to use:
At any given iteration, the thermocouples are only single values, of double precision format.
Therefore, I cannot use waveform max/min.vi. I also can't do anything with arrays because I don't have an array.
I have a feeling I need to do something like use a shift register to store the value each iteration,
but could someone help me out with the specifics of what I should do?
Cory K
Message 13 of 13
(674 Views)
