Display warning message-Infinite loop
I have attached a VI which just shows an animation of water level control. Whenever the level increases above a limit, a warning message is displayed.During execution, the display enters infinite loop. I want the warning to disappear when pressed "OK" button and ten turn the pump off.
Anyone please modify the program.
Smiley Indifferent
Thanks.
Arihant.
(4,136 Views)
I have just modified the Vi
Check the attachment
(4,121 Views)
Hi Arihant,
Try This.
Bijay
(4,113 Views)
That was so simple. Silly me.Smiley Very Happy
thank you very much.
However i see that the level change is not there if we dont press OK button. Say there is some delay in pressing OK, shouldn't the level of tank be increasing?
It would be great if possible.
Thanks.
(4,104 Views)
I think you should have a go at coding that yourself.
Bijay and Mangesh have already been very helpful so far, but this forum isn't a code writing service! If you want someone to write code for you, then I suggest you employ a contractor at a contractor's rate of pay!
Have a go at solving your issue yourself and then ask back if you have any specific problem. The time spent getting the basics under your belt will be well worth it in the future.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(4,094 Views)
Thanks CC. I will keep that in mind.
But dont you think you should mind your own business rather than advising people free of cost.
(4,079 Views)
Touché! Smiley Wink
But my point still stands - it's always more rewarding in the long run to understand these things yourself
(4,076 Views)
