Display two 1D array to XY Graph
I want to display the value of two 1D array, and one is for x axis, the other one is for y axis in XY Graph, how to process this ?
Thanks.
Keep moving
Message 1 of 10
(5,475 Views)
Bundle the two arrays or create a complex 1D array. The xy graph accepts both.
Message 2 of 10
(5,466 Views)
Hi Sir,
Not quite understand, i try to convert the array to the input of XY Graph, but always the wire is broken.
Keep moving
Message 3 of 10
(5,461 Views)
Accepted by topic author Brzhou123
Well, you are not really telling us what you are doing, so we cannot tell what you are doing wrong.
Given two 1D arrays of same length (one for X and one for Y), here are two (of many more!) possibilities.
Message 4 of 10
(5,454 Views)
Well, it works with the 2nd method, but could you still tell me where to find below icon in the first method ?
Thanks.
Keep moving
Message 5 of 10
(5,447 Views)
Bundle  (Cluster, Class & Variant palette)
Message 6 of 10
(5,444 Views)
Thanks.
Numeric >> Complex palette.   Polar to Complex
Message 7 of 10
(5,373 Views)
RE/IM to complex, right?
(Sorry, I thought that's what he already wired up and I thought the bundle code was missing. 🙂
My "first method" described here was the bundle: "Bundle the two arrays or create a complex 1D array. The xy graph accepts both.")
Message 8 of 10
(5,370 Views)
Yes.  You're right.  Them being on the same palette, I just looked at the name of the wrong one.
I just realized in his message about "the one below", he meant the image below his text in that specific message, but I could see how it could have been read as the image that was at the bottom of the image "below" of your message with both examples.
Message 9 of 10
(5,353 Views)
Brzhou123,
You should accept Altenbach's message #4 as the solution to your problem.  All my messages were just to help clarify the followup questions you had.
Message 10 of 10
(5,341 Views)
