Display tokens in text file
Hello All;
I am working on some text file update VI's, and I am having quite a bit of trouble with tokens...
In order to get all my offsets and such correct, I need to input a text file (using Read From Text File), but I want to display all tokens with the text. I've played around with the Scan String for Tokens VI, but cannot get it to do what I want it to.
I am attaching a sample text file.  Is there a quick way of doing this?  (i.e. read from file, put into string, scan entire string and output same string with both text and tokens visible)...
Thanks.
D. J. Hanna
(3,318 Views)
Hi Hannamon,
your example text file cries for using "config file" (aka ini-file) functions! They can be found in their own subfolder of the file palette...
And there are some examples coming with LabView too! (Search for "configuration".)
Message Edited by GerdW on 10-25-2007 03:41 PM
(3,313 Views)
Hi All;
True, I did create the original text file using the Config File VIs, however! my need for a text file editor has outgrown their usefulness; perhaps I should have explained my full application intent:
I have a text-based configuration file that is used by multiple software platforms, and is already in existence.  I am not versed in these platforms, and so my platform of choice is LabVIEW.  I need to pull certain configuration and variable information from these text-based files and use them in my LabVIEW application.  These text-based files are set up in a format significantly different that would be useful in a Config VI, and I do not have the option of reformatting the text-based file to suit my needs.  Think of it as a "one text-file format for all applications" type of idea.
Hence the need to identify the string tokens as part of my original post.  (GerdW: normally a good idea, I agree!  But I hope my explanation clarifies my current need.)
DJH
(3,291 Views)
Hi Hannamon,
then you shouldn't attach a text file that definitely looks like an ini-file Smiley Wink
When you can't use the config file functions you have to program all their possibilieties on your own Smiley Sad
Well, I would try to use the string functions (like Scan from string, Match pattern, Spreadsheet string to array,...).
See the attachment to get a clue.
(3,273 Views)
Thanks, GerdW;
Sorry about the initial confusion; for me it was more of a "next logical step" from config vi to a general text file reader 😉
I think the spreadsheet string to array.vi will probably be an easier route for me to go, since each line item contains system information, and I can just parse it accordingly!  I'll give it a go, and update the thread on my progress.  Thanks for the example!
D. J. Hanna
(3,260 Views)
Just to close out the thread, the Spreadsheet String to Array turned out to be what I needed... this handled the eol quite nicely, and I only had to reverse the process to write the file.  Thanks!
DJH
(3,224 Views)
