Display letters instead of numerical values on labview using joystick
How do I display letters instead of numerical values from joystick? Eg. Instead of getting numerical values to display on labiew from the joystick, i want to see letters....
Message 1 of 8
(3,846 Views)
Please explain what you mean by letters instead of numbers.
Message 2 of 8
(3,838 Views)
For example, When I push the joystick forward I get numerical values such as "200" displayed on the VI. Instead of getting numbers i would like to know how i can get letters such as "w" when i push my joystick forward. hope it's clear now...haha thanks 🙂
Message 3 of 8
(3,823 Views)
Hi Doyoyo,
you could use a case structure to "translate" numbers to letters.
Or you could use a lookup table of char vs. index…
Message 4 of 8
(3,799 Views)
Hi GerdW,
will try it out! thank you!
Message 5 of 8
(3,774 Views)
HI GerdW, do you mind showing me a demo?
I have attached a program to this post, could you show me how I can change the output of the axis info to letters?  The Front panel shows axis info....for eg, X axis...if the number is above 0 to show "L" and if the number is below 0 to show "J"?
Message 6 of 8
(3,769 Views)
Hi doyoyo,
as I can't open your VI (I only have LV2011 available here) I created a simple example:
The upper part shows the lookup table suggestion, the lower one the case structure approach…
Or like this:
Message 7 of 8
(3,760 Views)
Hi GerdW,
Will take a look at it! thank you very much for ur effort :)) appreciate it!
cheers,
Doyoyo!
Message 8 of 8
(3,749 Views)
