Display from AGILENT DSO
Hi everyone,
I am trying to reproduce what i can see on the AGILENT DSO6032A on a LabVIEW graph.
Enclosed is a picture of what my DSO is displaying : it's a frequential sweep between 200kHz and 15MHz.
However, when i get the waveform from my VI, i get a poorly sampled version of my signal (screenshot and VI enclosed).
Is it because my DSO goes to 2G samples per second and the VI can't follow or is there a block in LabVIEW i am not using ?
Thank you,
Clement Z.
(2,524 Views)
I'm going to assume that you're using the Agilent 6000 series LabVIEW drivers?
If so try using the "Configure Timebase" VI to set the min record length to MAX.
If using direct VISA commands try WAV:POIN MAX
(2,481 Views)
