Showing results forĀ
Search instead forĀ
Did you mean:Ā
Display data in Command Prompt
I am logging data in text file in parallel I would like to display the CMD prompt as console output.
Something like Printf function.
How to achieve this.
Visuman
Message 1 of 8
(8,082 Views)
Can you made string indicator and update it?
Or you want write in win CMD?
Message 2 of 8
(8,080 Views)
I want to write in windows command prompt.
Message 3 of 8
(8,073 Views)
there is the "System Exec.vi".
and cmd /c echo "Hello World!" for the 'command line' input will print to the command line. but a new window will open and close immediately.
even if you start you VI.exe from the cmd window, output from the system exec vi will not be seen there.
the best solution would be to log to file, and you could use the windows equivalent of 'tail -f FILE'.
but i'd like to be corrected.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 4 of 8
(8,048 Views)
Yeah agree, I don't want to open each time separate CM window.
I do open the EXE with batch file and I would like to update the status of exe in the same CMD prompt.
Thanks Visuman
Message 5 of 8
(8,043 Views)
a hackish solution:
save the following as "run.ps1"
Start-Process "BASEPATH\labview-cli-test.exe" -WindowStyle Hidden
Get-Content "BASEPATH2\test-logfile.txt" -Wait
then from a powershell run "run.ps1"
this will execute labview-cli-test.exe in the background, and then it will wait on changes to test-logfile.txt until you stop with CTRL+C.
note that the test-logfile.txt must exist when the command is executed
Message 6 of 8
(8,034 Views)
While executing showing error unknown parameter "run.ps1"
in CMD window.
Message 7 of 8
(8,000 Views)
as i said in my post, this is a powershell script,
CMD prompt does not have the necessary tools.
Message 8 of 8
(7,993 Views)
