Display current state (value) of analog output
Is there a way to display a live numeric value on the screen of analog voltage output.
For example: when Dev/a0 ouput is connected to an external scope, you can see the voltage on the screen.
I would like to see this value 0 -10V as a numeric on the screen just as I can see it on the scope.  I dont need to see a trace just the current state (value) of the analog voltage ouput.
(2,784 Views)
Just connect an indicator to the input of your DAQmx Write.
(2,781 Views)
