Display components resizing when Running Vi
I am running Vi to my pc and it displays all control as on Position. However, if I run this application on a different PC, it changes the controls' position.
Here are some photos of it.
Figure 1: --->This is into my PC as I decided to do that.
Figure 2: ----> To the Other PC.
All the texts increased the distance. And not in the specific position.
Can Someone help me through it?
* This Settings I already have
(635 Views)
Hi Rshah,
Why did you enable "scale all objects"?
And as you seem to run an application (aka executable): did you set your preferred font in the executable.ini file?
Is there the very same display scaling setting in Windows on your computers? This may influence the look of your frontpanel, too.
(628 Views)
Turn off Windows Scaling for that app. Properties -> Compatibility -> Settings for DPI -> Disable DPI scaling (words might be a little off, i don't have English Windows) 🙂
Qestit Systems
Certified-LabVIEW-Developer
(548 Views)
