Display color array then 1 second later display same array with color change
Hi there, I'm new to LabVIEW and this is my first post. I'm using LabVIEW 9.0.1
Please have a look at this simple program attached below; when I've worked out this part of the program, it will be the starting up sequence of a game
the lights need to be set to white before running the program.. When the program runs the hexadecimal 'array 2' is projected as colors on 'array'. Then 1 second later, a green light is added to the centre and displayed in 'array 4'...
I am attempting to have the green light go on on the same array after 1 second. As opposed to on array 4...
When I've figured out how to do this I'll add many more time iterations, whereby a color is changed on each one. Thus making a nice startup sequence.
any help is appreciated, thanks in advance for your help!
p.s. add 00FF0000 to the last box in 'array 2' before you hit play.
(2,830 Views)
I think you should learn about shift registers.
Your larger program will probably work better and be easier to modify and maintain if you use a state machine in place of the sequence structure.
Lynn
(2,813 Views)
thankyou verymuch, i got it working now!
(2,805 Views)
