02-16-2023 06:17 AM
I want a LabView program who calculates the temperature at which a flow of water is heated with the help of a resistance. The program includes:
Thank you! 💛
02-16-2023 06:43 AM - edited 02-16-2023 06:46 AM
Hi daughter,
@labviewsdaughter wrote:
I want a LabView program …
Simple answer: then you need to create such a program!
The generic answer for your rather generic question is:
02-16-2023 06:48 AM
Thank you! 💛
02-16-2023 06:53 AM
02-17-2023 03:59 AM
Hello! This is the code.
02-17-2023 04:06 AM
02-17-2023 08:30 AM
19 VI and thank you again!
02-17-2023 08:59 AM
Hi daughter,
- entering the necessary data (flow of water and Power of resistance) through elements on the front panel or by reading them from a file
- the possibility of changing the flow of water and the Power of resistance values from the front panel and to display the results on a graph Temperature=f(time)
- the possibility to save the dates in a text file
All this is already found in your VI, so what is the actual question/problem?
Recommendations:
