Display Large Files
I have a large file saved from labview that is 20 mins of data. I try to display it in Excel but the file is to big and doesn't load completely. I was wondering if there was a different program or a way that can load the file and display the analog information back to me, so that I can analyze and go over the data of why certain things occured.
(4,303 Views)
Well LV can do it. What format is the data in and how are you wanting to display it? graph? table?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,294 Views)
Hi Pete,
have a look at Diadem - the big data presentation/mining program also distributed by NI!
It can handle Excel data but isn't limited in the same way as Excel 🙂
Yes, NI does a lot of advertising for this program. No, I'm not working for NI Smiley Very Happy
(4,288 Views)
Yea it saves in a .csv format
(4,258 Views)
It saves an analog sihnal, and I want to just display the signal back ... so yea a graph would be fine ^^
(4,232 Views)
If you want to do it directly from LabVIEW, check out Managing Large Data Sets in LabVIEW.  You may also want to open up the LVM read express VI.  It has a few chunking techniques that may be of interest.
Let us know if you need more help.
(4,184 Views)
The example data is only a small size of 300 scans for 4 channels. This is too big to fit in excell as you have the scans as columns (excel has a limit of 256). If you transpose your data before you save then you will get 4 columns and 300 rows. This will then fit into excell (up to about 65000 rows I think).
With your data as it is the attached file shows you the basics to read your file into Labview.
Ian
(4,175 Views)
