Display Data Information from 2D array and show in graph
gregoryj I tried the solution you suggested but the problem is x- axis is based on sampling rate so I used property node for X scale and then multiplier. But when I use index array as you suggested the n-dimensional array is data. Then in the output I connected the XY graph but the time interval is negative. So, how can I use the time created by X scale multipler and data information which is going to the index array?
Message 11 of 13
(996 Views)
I do not understand. Can you run your VI once so that the indicators fill up, then go to edit >> make current values default. Then if you are using newer then LabVIEW 2012 go to file >> save for previous version... and save for 2012. Then put everything in a zip folder and upload it.
If something is too confidential, then please feel free to change the names and populate with fake (but realistic) data before uploading. You can change the names in just the 2012 version so it won't effect your main program.
Message 12 of 13
(988 Views)
Thank you for your help !! I actually just got it working.
Message 13 of 13
(982 Views)
