Disconnect without losing the reference
I want to transform a linked property node for instance into an unlinked property node with a connected reference?
I know how to disconnect, create the reference again and connect it. I just want to know if there is a way of doing that quick and easy, preferably with one click or key stroke combination 🙂
If you look at the snippet you'll understand what I mean by that.
(3,046 Views)
Hi Eddie,
that looks like a task for LabVIEW scripting in combination with a QuickDrop plugin.
Maybe there already is such a plugin?
(3,017 Views)
Hi Sugar,
It takes me about 7 clicks 🙂 Do you anticipate having to do this a lot?
Is it because you want to put the code into a SubVI? If so, just select the (linked) property node, click Edit >> Create SubVI and it will create the reference for you.
(2,990 Views)
Thanks for the reply guys!
@gregoryj I tried doing that but I have a lot of property nodes in certain parts of my code. So making subVI's with that many nodes just creates too many input terminals for my taste. I find it visually more appealing to bundle all the references in a cluster and unbundle them in my subVI, that way it narrowes the input terminals down to one.
(2,967 Views)
