Disabling the Port
Hi all,
Assume that I have built an EXE and enabled the port for it by editing the .ini file.  Is there any way while running the EXE disabling/close the Port used by the Same EXE ?, also it should not close the Application.
(2,842 Views)
Exactly what kind of port are you closing?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,800 Views)
I have to disable this "server.tcp.port", for debugging I have to simulate this while running the EXE
(2,783 Views)
