Disable menu ring depending on conditions
Hi all,
I have two menu rings and I want to disable one of the two menu rings depending on the value set with the first meu ring.
More precisely if I select "option 1" with the first menu ring I would like to have the second menu ring disabled and fixed on a certain value that is the only possible value allowed for the "option 1".
I need to use the menu rings because if I select "option 2" on the first menu ring, I must be able to select among all the possible values of the second menu ring since they are all allowed.
How can I do that?
Many thanks in advance!
(2,007 Views)
Accepted by topic author mol90
You can play with the menu properties values. See below the example.
(1,998 Views)
Hi mol,
@mol90 wrote:
How can I do that?
  • Use an event structure to handle value change of MenuRing1.
  • Read the MenuRing1 value and wire it to the selector of a case structure.
  • In case "Option1" you use a property node to disable (and gray out) MenuRing2 as well as set it's value to the desired item.
Edit: As shown by Defaphe…
Are you really working with Rings - or do you use Enums? It sounds like you are using a static number of items…
(1,996 Views)
(I agree that you might to work with enums instead. Would simplify certain things.)
The solution you got above will disable the entire second ring. A more flexible option would be to use the "Disabled items[]" property node. Now you can disable specific items as needed. Maybe later you want to allow more than one, but still not all items. 😄
(1,969 Views)
