Disable Right Click On Plots
I would like to disable the right click on plots in my application. Any way to do this?
(3,000 Views)
You can disable it for all controls and indicators by selecting vI Properties>Window Appearance>Customize and unchecking Allow Run-Time Shortcut Menu. Tos disable it for just some of the front panel objects, place a transparent decoration on top.
(3,000 Views)
If you don't need to interact with the graph (changing scales, moving cursors, and whatever during runtime); an option is also to disable the graph by its property node.
Alberto
(3,000 Views)
