Disable Code based on OS at Compile Time
Hello. I am trying to create an application that can be compiled for the big three OS': Windows, Mac, Linux. I have some code that I wish to run on the Windows version that references DLL's. On Linux and Mac I don't care about these sections so I used a conditional disable structure that switches based on target type to switch between the windows code and the no-op for Linux and Mac.
This works fine in source, however, when I compile the application, the build will fail on Mac or Linux because the sub-vis that exist within the Windows case of that structure are not executable, even though they will never be run.
Is there a good work around or solution for this? Thanks.
(2,694 Views)
Hi!
Have you tried using "OS" instead of "TARGET_TYPE"?
Disabled code should not be considered while building the application.
Marco
(2,672 Views)
