Dimension measurement from image
Hi all,
Has anyone found a way to calculate dimensions from an image given the knowledge of one dimension?
I'm hoping to reverse engineer dimensions of an object given a photo and prior knowledge of at least one dimension visible on the photo.
I understand that you would need to correct for perspective errors, but the accuracy of dimensions could be increased using multiple images from different viewpoints.
Any thoughts or advice would be most welcome!
P
(3,718 Views)
Hi Toad,
Here you can find a community solution for this issue:
https://decibel.ni.com/content/thread/10141?tstart=0
Good luck with your project!
Luigi
(3,661 Views)
Have you considered trying NI Vision? There are software tools there that achieve everything you've mentioned in your post. This would be quite difficult to do otherwise.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,657 Views)
Thanks Richard,
Phill
(3,647 Views)
Thanks Luigi,
Phill
(3,645 Views)
