Digital port programming
I want to program a DAQ-Card. I want to enter an integer coded on 8 bytes and
send this integer on a digital port of my card. I only have succed in programmng
one line of the port and not all the lines.
Does any of you have an example,
Thank you so much...
Frederic
PS : as you can see I am a beginner...
frederic.restagno@college-de-france.fr
User of http://www.foorum.com/. The best tools for usenet searching.
(3,004 Views)
Use the Write to Digital Port.vi located on the digital IO palette. Just wire-up a decimal value to the input...
Michael Aivaliotis
VI Shots LLC
(3,004 Views)
Frederic;
If you are using Labview, you can find a good example for you to start at Search Examples->I/O Interfaces->Data Acquisition->Digital Input and Output->Immediate Digital Input and Output->Write to One Digital Port.vi.
If you are using any other Programming Language which NI-DAQ has API for, you can fing some examples at C:\Program Files\National Instruments\NI-DAQ\Examples, if you already have NI-DAQ installed on your machine.
Hope this helps.
Filipe
(3,004 Views)
