Digital data logger
I have installed a DAQCard-6533 wired to SCXI-1000 chassis and one board SCXI-1162HV.
I've configured with MAX two channels the first is the channel to Dev1 port PA0, teh second is the channel to Dev1_SC1_MD1 DIN1.
I use the digital data logger to log the input from lines 4 and 7 and the digital data reader to view the results, but i have probles to view the data.
I am running the digital data logger with the following configuration device=1 and portlist=0 clock=internal.
The digital data logger writes a binary file but when i try to read it with the digital data reader the graph doesn't shows any data.
My questions are, is correct the configuration of the data logger (device=1 portlist=0) to read the channels 4 and 7?
How can I know if the data are in the binary file?
How can I view the data with the digital data reader VI?
How can I configure the bus pattern to know the presence of signal in the channels 4 and 7?
(3,213 Views)
The first five lines of the 6533 card will be used for data transfer and communication with the SCXI chassis. Therefore, you should not be making a virtual channel of port 0 of the 6533. You can get access to the unused lines on that card, however, you'll need a feedthrough panel (like an SCXI-1180 module) for that.
I am assuming that you are trying to read data on lines 4 through 7 on the 1162HV module. In that case, you can go ahead and make a virtual channel for the 32 bit port on the 1162HV. You need to use that virtual channel in the 'portlist' input. You can also enter the string: sc1 ! md1 ! 0 in the portlist.
In order to check if there is any data in the binary file or not, just check its size by looking at the file properties.
You should be able to view the da
ta using the digital data reader vi as long as you specify the correct file name and reading parameters. Look at the vi description by brining up the context help for more details.
If you still have trouble reading data, then I would suggest that you run the scxi example vi for the 1162 module. This example is shipped with labview and is located in the labview/examples/daq/scxi/ folder. It is a simple vi for reading in data from the 1162HV module.
Afreen S.
www.ni.com/ask
(3,213 Views)
