01-28-2019 09:03 PM
Dear all,
Currently i am facing a problem where my digital waveform cannot show all plots in the graph. I had configured total 31 line for the graph but it only show 29 line eventhough there are some empty space at bottom. May i know is there any maximum line to plot a digital waveform graph? The plot is start from line 3 to line 31. I had tried to enlarge the graph area but it still the same. Here i attached my vi for your reference.
01-29-2019 12:57 AM
01-29-2019 06:05 PM
Hi GerdW,
Thank you for your reply. I already enabled the y-scale auto scaling and re-run the program. But it still the same.... You can make all lines appeared after enable auto-scaling?
01-29-2019 06:11 PM
Hi GerdW,
I made the property autoscale in program then only it works. Thank you for your help 🙂
01-29-2019 11:55 PM
01-30-2019 08:15 AM
I had been reading this thread from the beginning. After I saw your message about turning on autoscale, it felt like it didn't help me either. But then after your further messages, I tried it and it did work.
I have no idea the difference between the original and attempt and later. Something is erratic about that graph. Latest check, turning on autoscale seemed to make it work, and I did not need to add a property node.
