Digital Tacho with USB-6009
I'm trying to use the USB-6009 and a 9233 in a USB chassis for an Order Analysis program.
Results were unsatisfactory with an analog tacho into the 6009 (buffer overflows if rate set too high etc...) so I would like to use the counter instead but I'm having trouble figuring out how to do this.
This is what I've got so far in my test program but the speed simply increments upwards of 500M or so.
The DAQ Assistant is configured as follows:
Type = CountEdges
Active Edge = Falling
Direction = Up
Initail Count = 0
Input Terminal = PFI0
Acq Mode = 1 Sample (On Demand)
Any help would be greatly appreciated.
(4,010 Views)
Hey,
I'm not quite sure what you mean by "the speed simply increments upwards of 500M" but I would recommend you take a look at the example VI titled Even Angle Reference Signal Processing (Digital Tacho, DAQmx).vi.  It is located in the LabVIEW example finder (Help»Find Examples...)  under Toolkits and Modules»Sound and Vibration»Analyzing and Processing Signals»Order Analysis
Doug F
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(3,982 Views)
