Digital Sampling in LabVIEW (encoder)
I have a circuit with 2 digital outputs:
1) on the first output a pulse is generated in conjunction with the measurement of an encoder.
2) the second output generates a logical high or low depending on the direction of travel determined by the encoder.
What I need is a reliable way to determine when a pulse is generated and then count up or down depending on the state of the second output.
I tried to use a count events VI and perform a digital read when the counter incremented, but this didn't work. What is the most efficient way to do this?
Jordan
(3,042 Views)
Jordan,
There are example programs that were built to interface our multifunction DAQ devices with encoders. Our E Series DAQ devices have 2 24-bit counters that have an up/down pin associated with them so they can count up or down based on the input state of the up/down pin.
The example linked below is a LabVIEW example that shows how to use an E Series device with an encoder to count up or count down. I've also linked a document that explains how E Series devices work with encoders. I hope this helps.
Quadrature Encoder with DAQ STC (E-Series Boards)
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E9AD56A4E034080020E74861&p_node=DZ52326&p_submitted=N&p_rank=&p_answer=&p_source=Internal
Using Quadrature Encoders with E Seri
es DAQ Boards
http://zone.ni.com/devzone/conceptd.nsf/webmain/6F25CBA2CD73417786256869005E5FC3?opendocument
Todd D.
(3,042 Views)
