Digital Reference for Lock-In Amplifier
How do you know that the simulation is correct? What frequency and what integration time do you use?
Since you used matlab instead of LabVIEW, you are probably asking in the wrong place.
Message 11 of 12
(661 Views)
How are you representing the numbers? Are you including the effects of A/D conversion? A 16-bit converter has a nominal dynamic range of 96 dB, so going beyond that requires considerable care in the signal processing.
Getting any hardware system to work over a dynamic range of 100 dB or more is not a simple or straightforward process. For a full scale signal of 10 V, 0.1 mV is -100 dB. So every amplifier, filter,  and digitizer in hardware must have noise and offsets below 100 uV while handling 10 V signals over the entire input bandwidth. After digitizing any quantization noise, overflow, underflow, and data representation size must not reduce the dynamic range.  Non-linearites in both hardware and software must be carefully characterized and managed to assure signal integrity.
Timing resolution can also introduce errors in digitized representations of lock-ins.
Did your simulation do all of these things rigorously?
Lynn
Message 12 of 12
(649 Views)
