Digital Output control (daqmx)
Hi Community,
I have an NI 9485 SSR module which I'd like to use to turn high power SSRs on and off according to predefined schedule. I have created a VI (shown below) which does the job for me.
RLY0 refers to RLY0 in my schematic, RLY3 refers to RLY3 in my schematic. Coincidently I control RLY0 with Line0, and RLY3 with line3. (virtual channels defined in MAX)
The problem I have with this solution is that however I create the task from my virtual channels, I still need to refer to my outputs with an U8 port format so if later the wiring changes then its not enough to change the MAX settings, I need to change the source code as well. Ideally I would like to control my signals with a 2D array of booleans (switching would happen according to the RATE input), but I was unable to write a VI which does this. The closest I got is this, but the VI only switching RLY0 and RLY3 on and then off periodically and it doesnt seem to consider the 2nd row of the array.
I assume I am slipping on a banana and the solution would be quite obvious. Please help me out.
thx!
(5,531 Views)
Hey,
Could you expand a little on what the output is like? You said that the two lines switch on the then periodically turns off, could you explain a little more. Is it both lines that are seeing this behavior or just one? Does the line/lines turn back on after a period of time?
(5,462 Views)
Hey,
If I run the 2nd snippet then both outputs turn on for 0.5s and then off for 0.5s (and repeats it coupe times as dictated by the number of Samples constant). What I would like to realize is RLY0 blinking while RLY3 is always on. This is what I tried to realize with the 2D bool array. It does not work this way though.
thanks
(5,454 Views)
Hey,
It appears that you are trying to write to multiple Channels; however, you should just be writing to one channel. Try to use 1 Channel with 1D array Bools and update that value when you write to it, also you can try to write a 1 Channel 2D array Bools and index through it with a for loop; however, the cleanest solution is just to use the U8 data.
(5,405 Views)
Yeah, but the thing is that turning my outputs on and off should be extremely well timed (less than +/-1ms). If I write the channels one by one then the timing will be really incosistent. (same if I write the channels at the same time, but one set of sampe at a time). Except if there is a secret technique I am not aware of.
The first snippet does exactly what I want to do, but its bothering that if later I change the wiring then I will need to change the source code instead of just changing the channels in MAX. (eg RLY3 will be operated by line4 instead of line3)
(5,393 Views)
Hey,
So after looking into it, it appears that you will have to go with your first snippet of code and if your setup changes you with have to modify your code.
(5,339 Views)
Well... that sucks... I never had a problem like this with analog channels.
(5,319 Views)
