Digital I/O using DAQ assistant
How do I set up digital line input virtual channels AND line output channels using the same express vi DAQ assistant? The option to choose the siganal type only appears when the express vi is first opened.
(3,482 Views)
You can only set up the DAQ Assistants for either input or output but not both at the same time.  For that you will need two DAQ Assistants, one for each, running in parallel.
Brian
(3,468 Views)
Just in case you want an alternative solution that doesn't use DAQ Assistants, but lower level code, see the example attached.
Hope this helps also!
Stuart
(3,451 Views)
Thanks.
(3,436 Views)
