Digital Graph in LV 7.1
I have to display many signals in a Digital Graph with an exactly height in pixels selected by the user, for each signal. The reason of this is that I have to visualize on the left of the graph a Listbox with names, symbols... and each cell must have the same height of each signal. What I have done until now is to set the height of the signals is setting the Yscale maximum property of the graph.
But what I think is that the signals have different height. For example, if I set 50 pixels for signal and cells, the result is very bad !
Some suggestion ?
Many thanks.
(2,583 Views)
Hi Filippo,
I am not sure what you exactly need to obtain. Could you just explain more in detail your requirements and also post an example of where you are at this point in your VI development.
AlessioD
(2,558 Views)
