Digital Control Increment/Decrement Values
How can you change the values that a digital control increments and decrements? I want to have the data increment by a specific value based on another variable rather than by the default incremental value.
(3,417 Views)
(I assume you mean a "numeric control", there is no "digital control".)
Create a property node for the control and select property "data range:Increment" Now wire the desired value to it.
( You can also statically set the increment by right-clicking on the control ... "format and precision")
(3,417 Views)
All you have to do is create a property node and select datarange/increment then right click on the property node and select change to write and then wire your variable to that. If this is going to be a subvi then you would want to wire a control to the property node so that you can input your variable.
See Attached example
Joe.
"NOTHING IS EVER EASY"
(3,417 Views)
Obviously I'm new at LabView. Thanks! That beats my previous (non-working) solution.
(3,417 Views)
