Differnce in time while writing and reading time to a .txt file
I have done a code to store date in a .txt file and then read from that txt file and output that date into a time stamp indicator. But the problem the input time and output time are not same. I dont know why. I have uploaded the code. Thanking You in advance. Diff input time and output time.PNG
Message 1 of 9
(4,310 Views)
Your problem is that you use "%T" in your format string.  %T is absolute time which actually has the time first and then the date.
You need to change that to use the correct time format that matches the way you save time.  I got your VI working when I replaced "%T" with "%<%m/%d/%y %I:%M:%S %p>T".  Look up the format codes for time format string for more details on what each part means.
Pulido Technologies LLC
Message 2 of 9
(4,291 Views)
Could you please upload the working VI, which you got.
Message 3 of 9
(4,285 Views)
pulidotech wrote: I got your VI working when I replaced "%T" with "%<%m/%d/%y %I:%M:%S %p>T".
The Format Date/Time String defaults to "%c".  Therefore the Scan From String should have the format of "%<%c>T" to match.
However, %c uses the system format.  This is generally a bad idea.  If I tried to read the same string on my machine, it would fail.  So the format should be explicit on the Format Date/Time String and the Scan From String to make it consistant on all systems.
Message 5 of 9
(4,272 Views)
Thank You very much. I got it. I got it using %<%c>T. So when u said the format should be explicit on the Format Date/Time String and the Scan From String to make it consistant on all systems, I didnt understand. What does it mean.Which format should I use. Thanking You.
Message 6 of 9
(4,252 Views)
What he's referring is that when your formats should be explicit in both the write and read steps.  Look at the image for an example on a consistent/explicit %c format.
Message 7 of 9
(4,245 Views)
Thank u got it
Message 8 of 9
(4,237 Views)
Actually, I meant something more like this
Message 9 of 9
(4,225 Views)
