Differentiation between controls & indicators by reference?
Greetings. I would like to be able to set all the controls (but not the
indicators) on a front panel to a given state (e.g. F for bools, 0.00 for
numerics). However, the Controls[] property includes references to both the
controls _and_ the indicators.
Is is possible to determine programmatically whether any particular
"control" refnum points to a control on the front panel, or to an indicator?
I've looked at the problem from various directions, including the ClassID
and Type Descriptor, but so far I've come up empty.
Justin Goeres
Indio Systems, Inc.
Pleasanton, CA
(2,581 Views)
There is actually a Knowledge Base on our website that discusses this issue and includes a VI that should accomplish what you are trying to do. Here is the info on it:
Programmatically Determining if an Object is a Control or Indicator
KB 26K9A02L
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/32e64e35fc96e9f4862569fa0059b978?OpenDocument
Matt Kisler
http://www.ni.com/ask
(2,581 Views)
