Different wf_increment from sampling rate
Hi
I'm streaming data continuously to a tdms-file. The sampling rate is set to 3kHz. Oddly the wf_increment parameter is showing 0.000333325s in the tdms-file instead of 1/3000.
Can anyone give me a hint why there's this difference?
Because I need the correct value to build a time channel for postprocessing data in excel.
I have set the sampling rate per channel to 6000 and the rate of the clock to 3000Hz.
Thanks for your help
Yves
(6,411 Views)
Yves, could you provide a VI to reproduce this issue? BTW, what's your expectation? 0.000333333s  for wf_increment parameter?
(6,410 Views)
Thanks for your help. Yes, my exceptation is 0.000333333s.
An here's my vi.
(6,404 Views)
Yves,
There are at least two issues here.
1. 1/3000 cannot be represented exactly in binary. Create a simple example with a numeric indicator set to display >= 18 significant figures.  1/3000 = 0.00033333333333333332200.
2. Your DAQ device may not be able to generate exactly 3 kHz. For example suppose the internal clock is 20 MHz. 20 MHz/6666 = 3000.30003 Hz and 20 MHz/6667 = 2999.850008 Hz.
Lynn
(6,380 Views)
Thank you for your help.
Answer 1 is the relevant one. Obviously. I should have seen this too...
Unfortunately I have to set the rate on a similar rate. Because I need to reduce part of my data to 600Hz.
Well, I'll set the rate to 3600Hz. This makes the error quite small.
Yves
(6,352 Views)
