Different timeouts in multiple read / write operation in serial comm. in same VI
Hello all,
                       If in serial communication I have to write and read muliple times (In same VI) but the condition is for each write and read there is different timeouts then is it compulsory to initialize the serial port number of read / write times or there is another alternative.
for example say I need to perform three read / write operation.
1. Write a read b - timeout is 1 sec.
2. Write c read d - timeout is 3 sec.
3. Write e read f - timeout is 10 sec.
In above example a,b,c,d,e,f is just an example.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,723 Views)
You can change the timeout just by using a property node.  No need to reinitialize everything.
(2,721 Views)
Will it work if I do this immediately after first write and read and before second write ?
--Ranjeet
(2,719 Views)
yep
(2,704 Views)
