Different Bessel filter results 8.6 vs 2013
I have a question regarding Bessel filtering. I recently moved from LabView 8.6 to 2013 and by chance noticed a difference between filter results on the same prerecorded data between the two versions – 2013 seems to pass more of the original signal.
            The original data is from an impact test of a shock absorber recorded at 8000 Hz through a SCXI-1520 with 1K hardware filter fed to a 6052-E DAQ card. The reporting routine filters the force and travel info through a low pass Bessel 4 pole filter at 125 Hz and then reports max force and travel and the energy delivered and absorbed.
            After a bit of digging, I found that the call to lvanlys.dll for the Bessel coefficients returns slightly lower forward and reverse values in 2013. I then moved the 8.6 lvanlys.dll to the 2013 machine and parked it in a different directory ( not resource ) and created my own call to that dll for the coefficients. The results were closer but still passed a bit more signal. The energies are closer the theoretical values ( good ) but Engineering and Sales do not like the shape of the 2013 force – travel curves. More precisely, more “ripple” most noticeable at the beginning of the impact.
.           Does anyone have an explanation? One would expect that the same coefficients would be returned.
(2,504 Views)
Just a further note: the Butterworth filter results are the same between both versions of LabView
(2,501 Views)
Hey TomP,
This is actually documented behavior.  The Bessel Coefficient VI was changed in LabVIEW versions 2009 and later in order to better fit the Bessel Filter definition found in most DSP textbooks.
Myriam D.
(2,463 Views)
