Difference in NLSQ-Fit between LV7.0 and 7.1
I'm using a levenberg-marq fit to analyse some spectra. the fit works well under LabV 7.0 but not under LabV 7.1. when i searched for the error i found, that the "get new coefficience"-subVI delivered different results. for example under Version 7.0 the result for the input 1,0 / 1,0 / 1,0 / 0,1 for coeff/Beta/Alpha/Lamda was 1,83 while Version 7.1 showed 1,91.
Does anyone has an idea how to fix this problem?
Thanks in advance
(2,777 Views)
Hi Jayson,
Your are right there is a known problem in Labview 7.1.
You must just replace the get new coefficients.vi located in program\National Instruments\Labview 7.1\vi.lib\analysis\6fits.llb/ with the "Get New Coefficients.vi" attached under.
Let me know if that resolved your problem.
Best Regards
Matthieu Papaux
NI Germany
(2,763 Views)
It works fine now!
Thanks alot for your help
(2,757 Views)
