Difference in 60Hz filter response on pt by pt signal and other type
I am working on the design of a 60 Hz notch filter, i simulated the signal using pt by pt signal generation and Signal generation vis.
The problem is that with the Signal generation vis the filter works correctly but it doesn't filter the signals gernerated by pt by pt vi.
I have attached my file for reference.
Message 1 of 8
(3,200 Views)
Hello Abuzar,
Thanks for posting at NI forums! I opened the VI and noticed that the output of the pt by pt signal VI is unwired. I’m not really sure what you mean, but if you want to wire this output to the DFD Filtering.vi (as it is for the Array based signal); it will create a broken arrow. The output of the pt by pt signal is a DBL, not an array, which is the input required by the DFD Filtering.vi. Is this what you meant? Could you describe more why is it not working?
Best Regards,
Alina M
Applications Engineering
Message 2 of 8
(3,171 Views)
thanks amezam,
I actually connected the output of pt by pt once and then array based signal after disconnecting it.
So if the array based is connected, disconnect it and connect pt by pt signal
Message 3 of 8
(3,158 Views)
You can consider it as the file attached in this post.
Pls also explain me what is main characteristic difference b/w pt by pt and array based signal
Regards
Message 4 of 8
(3,155 Views)
Pls reply.
Message 5 of 8
(3,132 Views)
Hello Abuzar,
I ran the VI and reproduced that behavior. I’m investigating this issue.
Best Regards,
Alina M
Message 6 of 8
(3,121 Views)
Still waiting for the people on this forum to reply.
Message 7 of 8
(3,097 Views)
Hello Abuzar,
We are still working on this issue, and we will update you soon with our findings.
Best Regards,
Eric NI
Message 8 of 8
(3,063 Views)
