Difference between value change in property node and local variable
Hello
i was going through the property node and i found out the value change function in it. i saw some tutorials and i think its function is very similar to local variables.
Pl correect me if i am wrong. could someone explain the differences as well
regards
jalashwa
(3,598 Views)
Hi. They perform basically the same function although performance is slightly different.
The VI in this link demonstrates the difference ...
http://www.ni.com/example/27031/en/
(3,571 Views)
What Neil said. Short answer is to always use a local as it's faster. The 'value(signaling)' property has its own uses, but again never use this unless you have a specific reason. (It triggers front panel events which is only of use on some occasions when you are using event structures.
In a nutshell, use a local in preference unless you have a specific reason not to.
(3,562 Views)
NeilR wrote:
The VI in this link demonstrates the difference ... http://www.ni.com/example/27031/en/
Wow, that's a horrible example! Who wrote this thing??? 😮
  • Stacked sequences
  • hidden wires
  • hidden code
  • several representation mismatches
  • unreasonable default value
  • no outer while loop, forcing continous run.
There are plenty of long discussion here in the forum, try a search. (Here's even a very old benchmark)
(3,534 Views)
This is one of those pet peeves of mine.  At one point in time, NI just said "Don't use local variables".  But never explained (well) why or what to use as an alternative (like WIRES or SHIFT REGISTERS).  So I had a bunch of coworkers, instead of using local variables, would use the Value property node.  Then I went on a crusade.  In the bechmarks I made at that time, the property node was a good 10x slower (if not more) than local variables.  The reason for this is that the property node forces a thread swap since property nodes that affect the front panel must run in the UI thread.
The Value (Signaling) property is useful if you need to cause the event structure to respond to you programmatically changing a value.  But you need to be careful because, even if you didn't change the value, the event will be fired each time the property is written to.  You are generally better off using User Events anyways.
(3,526 Views)
Wow, that's a horrible example! Who wrote this thing??? :smileysurprised:
Don't know, but NI seem to think it's good enough to post as an example. Smiley Very Happy
But seriously, you're right Sir A, examples should be of a high quality and demonstrate good coding style and functionality.
Maybe we need to get the select few members of 'The NI Round Table' to do some judicious editing.
(3,515 Views)
